Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1438 Questions View all
HELP! White tab fell off of Hard Drive before removed...
I am trying to replace my hard drive and the directions say to pull the white tab to the right to remove the hard drive. I must have pulled too hard b/c the white tab broke off and my old hard drive is still in the computer. Any suggestions on how to get it out?! Thanks!
Comments:
Thanks! I ultimately had to open up the lower case and lift out the keyboard to get to the hard drive. Oh well! At least the installation was successful. Thanks for your thoughts.
by
Add a comment
Spread Fixmas Cheer
Get $12 off your purchase of $50 or more with code FIXMAS12
Spread Fixmas Cheer
1 Answer
Chosen Solution
This will probably require getting deeper into the guts of your laptop, but if you wish to avoid this you could first try to get a grip on the Hard Drive Bracket. The bracket is the thin piece of metal visible in step 5 of the Hard Drive Replacement Guide. The space between the hard drive and the laptop's lower case is very slim so you would need pliers or tweezers with wide and thin flat jaws. If the hard drive is out part way this will be easier. If the drive is still all the way in and if the tab tore off with some force it is unlikely that you will get enough grip to remove the hard drive.
If there is no way to grip the hard drive bracket then you can follow the Hard Drive Connector Guide to step 13. At that point you should be able to slide the hard drive out with out the white tab. This does require opening the case, a moderately difficult task. Look over the guide steps before you begin and look over the tools required for the job.
Good Luck!
MacBook Core 2 Duo Hard Drive Image
Guide
MacBook Core 2 Duo Hard Drive Replacement
Difficulty:
Easy
15 - 30 minutes
MacBook Core 2 Duo Hard Drive Connector Image
Guide
MacBook Core 2 Duo Hard Drive Connector Replacement
Difficulty:
Moderate
Add a comment
Add your answer
keristuebinger will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 8
All Time: 1,270
