Loud noise to my laptop how to repair
I hear Loud noise to my laptop and how to repair
Had this happen on my old laptop, turned out the cooling fan was packed with dust and running overtime. Cleaning the fan fixed most of the noise, and replacing the fan completely solved it later.
To repair a loud noise on an Acer TravelMate P2 (TMP214-52), immediately clean the vents and fan with compressed air to remove dust buildup. If the noise is a grinding or buzzing, replace the CPU cooling fan, which is often caused by failing fan bearings. Listen to see if the sound is a consistent, high-pitched whirring (indicates a failing bearing) or just a loud, rushing air sound (indicates overheating). If cleaning does not resolve a grinding sound, the fan bearing is likely failed. You can replace the CPU fan yourself, as the part is generally available online (search for "TravelMate P214-52 CPU Fan").
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 23
All Time: 116
