Teardown information for the Nespresso CitiZ coffee machine. They are available from different brands, e.g. Krups, DeLonghi.
Leaked after perfereted plate
Hi,
I have noticed that some of the coffee is leaked into the collector basket. In between the nossle and the brewing unit. I have taken the machine apart and tried to install a new brewing unit but some coffe Is still leaked into the collector basket. I have tried to clean the plate that punctures the pod but still coffee leakage happens. Any idea what could cause this and how I can fix it?
Be
Fredrik
Add a comment
1 Answer
If you replaced the brewing unit with a new one, and you thoroughly cleaned the diffusor plate, then the machine should be as good as new.
If leaking still occurs: Do you use / Did you try original Nespresso pods?
Other brand pods may work, but they also may be designed imperfectly: The rim of the original pods contributes to the tightness of the machine during brewing...
Add a comment
Add your answer
Fredrik Spadaro will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 14
All Time: 85
