ASUS TUF Gaming Laptop - FX505D-DBQ234T with i5-8750H and Nvidia gforce GTX. MFD-2019-05.
In my laptop wifi is not showing
I cannot see wifi option and I need to plug ethernet to run
Add a comment
1 Answer
@kshitijgharat double check your device manager and see if you can find your Wifi adapter. Also, check your BIOS to make sure it can see it. It is possible that you may need to reinstall the driver for it. It is also possible that your Wifi adapter has failed. In that case you may need to replace it. Use something like this guide ASUS TUF Gaming FX505DY Wi-Fi Card Replacement for that. Slightly different model but identical steps. Replacement adapters are readily available at many online places.
Add a comment
Add your answer
KSHITIJ GHARAT will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 8
All Time: 74
