Blade and its little base came out of shaft hole. How to get it back i
Blade and attaching neck came loose in grinding chamber. How to attach it back in so it engages?
1 Comment:
@nancyfortin let's have a look at what you got going on there. The blade should just screw back onto the motor shaft and there should be a spring clip that holds the bowl in place. ......anyhow, take a couple of well focused pictures and post those with your question. that way we can see what you see. Adding images to an existing question
by
Add a comment
