Shop the Holiday Gift Guide
An adjustable-color LED bulb from LIFX that offers Wi-Fi connectivity.
The bottom metal piece came off how do I put the wires to put metal pi
bottom piece came off how do I put wires and put back on
Add a comment
1 Answer
The light socket still has the rest of the light bulbs pieces! You first need to disconnect the lamp from the outlet or if that can't be done in the case of a ceiling light the power needs to be turned off!
This is required before continuing! As you could get badly hurt if the power is still on.
One you are very sure the power is not present at the socket see if you can grab the remaining piece still in the socket as the metal is sharp make sure to use something non-conductive to grasp the part and carefully remove it.
If you don't feel comfortable doing this you'll need to find an electrician to help you. Once the other piece is removed you should be able to plug in a new bulb.
Sadly, the bulb is not really repairable. Within the manufacture process the wires are spot welded to the two points the wires need to connect to. Soldering is not really practical and the the risk of fire if the joints are not firm. Best to just replace the bulb.
Add a comment
Add your answer
Melissa Gail Joyner will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 48
All Time: 160
