The Theragun PRO is designed with a powerful motor that delivers up to 60 pounds of force, and has a customizable speed range of 1750 to 2400 percussions per minute. It features a rechargeable lithium-ion battery that provides up to 300 minutes of use per charge, and a built-in OLED screen that displays speed and battery life.
Theragun Pro fourth generation battery ko.
Hi everyone,
I own a Theragun Pro, and unfortunately the batteries no longer charge. The charger is working properly, so the problem is the internal batteries in the battery compartment.
Can anyone give me advice on how to open the battery compartment to replace the internal batteries without causing any damage?
I'd be sad to no longer be able to use the massager, since it still works perfectly.
Thanks to anyone who can help.
3 Comments:
Are you sure the battery charger works? After several years of use, depending on how many times a week and how long per use, rechargeable batteries have a limited life. Sealed units are designed for replacement of the entire unit. However, diyers with some skills can find replacement batteries, disassemble units, disconnect or desolder connections, remove batteries and put new ones in. This presumes a unit still operates and isn't damaged electrically or dropped, causing damage. A multimeter is very useful for measuring voltage. Here's a YouTube video that may help; duck://player/FL1XVRs7qmk.
by
Thanks for your reply. The charger and massager work perfectly. The problem is the internal batteries, which unfortunately are no longer available. I was interested in information on how to disassemble the battery unit to replace the internal batteries. Do you have any suggestions? The YouTube link you highlighted doesn't seem to be correct. Thanks.
by
The video help with direct and indirect applications. Direct for similar units, indirectly for clues. Clues; the method manufacturers use to hide fasteners and snap together designs for form, fit, function, fashion,, etc. Snap together plastics like electronic remote controls, cellphones and other things not requiring screws saves on manufacturing costs. Hidden screws are often covered by stick on labeling, plastic, or metal ornaments as a way to prevent disassembly for many items not designed for repairs. These are throw away items after several years of use. Batteries are available online with some searching once they're identifed after removal. A project like this may be for above average diyers familiar with tinkering, rechargeable devices with replaceable batteries and soldering skills. As designed, the Theragun not allowing battery replacement is a throw away. Finding a small appliance repair shop may give some info on costs for professional repairs that may cost more than simply buying a new one.
by
Add a comment
1 Answer
Luckily for you, the design of your massage gun makes it easy to replace the batteries. BUT, Theragun stopped selling replacement batteries for this model, so you'll need to do some research and find a third-party battery that will work. Press the circular button at the bottom of the massage gun, above the battery, to pop it out.
1 Comment:
Unfortunately, I haven't been able to find compatible battery packs. After just four years of purchasing the massager, Theragun has stopped producing replacement parts, and I'd hate to throw everything away. I'll definitely never buy a Theragun again. I know someone has solved the problem by opening the unit and replacing the internal batteries. I'm hoping someone can help.
by
Add a comment
Add your answer
Alex will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 16
Past 30 Days: 51
All Time: 174
