The wiper delay isn't working where is the fuse or the relay located?
I have a 2010 hyundai accent and the intermit wiper isn't working where is the fuse or wiper relay located ?
Add a comment
1 Answer
Most Helpful Answer
Hi @davidmaruco
The intermittent function is controlled by the intermittent timer assembly which is located in the multifunction switch on the steering column.
If the wipers are working i.e. low and high speeds but just not intermittent then it could be a faulty switch, a faulty timer, a faulty potentiometer or a connection problem between the switch and the timer.
Here's an image of the wiring diagram that may help
(click on image)
Score 1
Add a comment
Add your answer
David Maruco will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 26
All Time: 107
