Can you identify this component?
Hi, Can anyone help me?
I turned my Macbook Pro (Late 2006 A1150) on the other day, everthing was going well until i tilted the screen. It caused the worn-down backlight cables to short which then fried something on the Logic board. I opened the Mac up an luckily found the broken component, however, it is so damaged that i couldn't read the code on top of it.
The part im looking for is a tiny black box with 6 pins (3 on two opposite sides).
It is on the bottom side of the logic board, to the lower right of the prossecor. below the component reads "Q9450"
(btw i did google "Q9450" and found nothing but processors)
Can someone please identify this component so i can purchase a replcaement.
Thank You.
Add a comment
MacBook Battery Fix Kits
Fix Kits Starting at $69.99
Starting at $69.99
Chosen Solution
just could not resist to answer this old question. I thought it might come in handy for someone else that has similar issue. The part in question is FDG6332C20V N & P-Channel PowerTrench MOSFET
Score 1
Add a comment
I'm afraid you will have to change the complete logic board.
I just fried my MBP's graphic card and this also could not be replaced separately - I had to have the complete logic board replaced.
Add a comment
Add your answer
alex will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 486
