My phone display has damaged I want to replace it?
how to replace my phone display
Your phone is fairly straight-forward as far as screen replacements go. Basically you take off the back cover, then unscrew the cover over the motherboard, which allows you to get to the display and battery connectors. Unplug those then remove the battery so you can unstick the screen's flex cable from the midframe. Finally, separate the display from the midframe, clean off the old adhesive, and you're ready to glue a new screen in place.
One thing I liked about this particular video is that they actually plugged in the replacement screen first to verify everything works before they glue it down. Other than that it clearly shows the steps needed in order to make this particular repair.
Xiaomi redmi note 13 5G screen replacement (dessembel and tear down) - YouTube
As you work, take lots of pictures then once you're done you can use them to create your own iFixit guide to Redmi Note 13 5G Screen Replacement. It's easy, fun and will earn the appreciation of the repair community, especially those who come after you with the same problem.
Good luck, and be sure to let us know how it all turns out!
Past 24 Hours: 2
Past 7 Days: 25
Past 30 Days: 51
All Time: 246
3 Comments
شاشتي يظهر بها ألوان وخطوط وحينما أضغط عليها تعمل بشكل طبيعي
by brahim idrissi
@brahimidrissi If your screen has colors and lines on it but pressure makes it work again, there are loose connections between the screen glass and the flex cable going to the motherboard. Unfortunately, those connections aren't repairable, so ultimately you will have to replace the screen to fix the problem permanently.
My brother found a workaround for a similar problem; he used a binder clip on the edge of the screen and removed the handles. That kept the phone working until I could install a new screen.
by Jerry Wheeler
English->Arabic translation:
@brahimidrissi إذا كانت تظهر على شاشتك ألوان وخطوط ولكنها تعود للعمل عند الضغط عليها، فهذا يعني وجود وصلات غير محكمة بين زجاج الشاشة والكابل المرن (flex cable) المتصل باللوحة الأم. وللأسف، لا يمكن إصلاح هذه الوصلات، لذا سيتعين عليك في النهاية استبدال الشاشة لحل المشكلة بشكل دائم.
لقد وجد أخي حلاً مؤقتاً لمشكلة مشابهة؛ حيث استخدم مشبك أوراق (binder clip) على حافة الشاشة وأزال ذراعي المشبك. وقد أبقى ذلك الهاتف يعمل إلى أن تمكنتُ من تركيب شاشة جديدة.
by Jerry Wheeler
