Digitizer problem bottom row icons don't work
The bottom row icons (above the home button) cannot be selected, so one cannot de-select running apps or control music
I have had this problem with iPhones and have fixed it by reseating the digitizer connector. In some cases I had to replace the whole digitizer in order to fix it.
If you are comfortable taking your touch apart, use this ifixit guide
iPod Touch 4th Generation Front Panel Replacement
I would start by disconnecting the ribbon cable, cleaning the connectors with 91% isopropyl alcohol, and then letting it dry for at least an hour. After reassembling the touch if it does not work, I would order a new digitizer.
Hope this helps!!
hyde
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,263
