13" laptop part of Dell's E6000 series, released 2011. The device features a removable battery, optical drive, and is compatible with a variety of E-Port docking stations.
Dell Latitude E6320 freezes at Windows logo after BIOS A13 update and hardware isolation
My Dell Latitude E6320 freezes at the Windows logo during boot. I have already performed the following troubleshooting steps without success:
- Updated BIOS from A08 to A13.
- Replaced the hard drive with a new SSD (tried both MBR and GPT partition styles).
- Swapped and tested individual RAM modules.
- Changed SATA Operation modes (AHCI and RAID On).
- Disabled Intel SpeedStep, C-States, Virtualization, and Multi-Core Support (tested with only 1 CPU core).
- Removed the Wi-Fi card, DVD drive, and all other peripherals.
- Replaced the CMOS battery and performed a hard power reset.
When I remove the RAM entirely to test the motherboard, the laptop does NOT beep. Instead, the fan spins at high speed, and only the Battery and Wi-Fi signal LEDs blink. Is this a confirmed motherboard failure, or is there a specific power rail or chipset issue common to the E6320 that causes this freeze?
2 Comments
@emechetaki82860 what version Windows are you running? Did this issue just come up or did anything precede this?
by
Windows 10 pro 2019(1903)
by
Add a comment
Chosen Solution
If u reflashed the BIOS then some of the MB is working including the CPU.
Much of the changes u made would have nothing to do with the problem
= SSD, AHCI, disabling things, CMOS battery.
RAM and things plugged it are potential failure items = so u eliminated them.
The system seems to be hung in POST and that would be because something on the MB has failed.
It is waiting for a response from that device and never getting it.
I had a laptop that did that because the USB circuit failed.
U would think it would time out and tell u what it was.
That required a MB replacement. Then the CPU shorted out.
1 Comment:
Was thinking the same the MB needs Replacement.
by
Add a comment
bios update may have been a mistake.
1 Comment:
It was freezing in Bios A08 had to flash in A13.. same issue persists
by
Add a comment
Add your answer
Emecheta Kingsley will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 52
All Time: 61
