Model No. A1367 / 8, 16, 32, or 64 GB capacity
914 Questions View all
Question Closed
I Replaced screen(workd perfect) I opened again and screen went white
Hi, i replaced my ipods broken screen and it worked perfect but then i found that wifi isnt working so when i replaced the wifi antenna i broke the wire(ribbonn) on left side almost half way down and when i put it all together the screen was white (the same screen workd perfectly before) i think it maybe the ribbon i broke? i could really use some help
I tried the home, volume, and power button thing didnt work
Add a comment
1 Answer
Chosen Solution
A hard reset should sort this out! It is a very common problem with iPod Touch 4th Generation screen replacements, hold the sleep and home button until it turns off and then power on normally.
That really should do it.
Hope this helps!
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 256
