Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White.
3237 Questions View all
No Signal and I have parts left over?
Hi
I have a slight problem i do hope you can help me ,i have parts left over after i have replaced the mid frame bezel with a gold one. it now has no or little signal and i have a hook shaped metal bracket left over and another minute like slide over screw contact thingy , help please
Add a comment
1 Answer
Chosen Solution
Oil from your fingers can interfere with signal, using a degreaser on all metal-to-metal parts should sort that out for you but, not as much as finding out were that small piece should go! The small metal brackets (with a golden colour) are used to zero certain tracks. For signals this is vital and that is your best bet at sorting out the problem!
You have done a really cool modification to your iPhone, but in doing so you have done effects similar to holding that small black line in the lower left-hand corner on the iPhone 4G, just internally.
Hope this helps!
Add a comment
Add your answer
nathan will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 540
