Early 2011 Model: A1278 / 2.3 GHz i5 or 2.7 GHz i7 processor
782 Questions View all
Question Closed
Less contrast in section of screen, around apple logo
Hello,
Since a few weeks i'm having a section of less contrast on my LCD-screen.
You can only see it with a dark background, it is like there is some moisture under my screen, but this should not stay there for a long time if it really was moisture.
It is on the same place where the Apple-logo stands at the back of the screen. Actually around the place where the Apple-logo stands.
Does anybody know what it is ? And if yes, do you know what you can do with it ?
Thank you very much in advance,
Thomas
Add a comment
1 Answer
Chosen Solution
Are you in a brightly lit room? The Apple logo on the back can actually let light in throughout the back of the display. If I shine a light through the Apple logo then I loose contrast due to the light. Tis can also happen if you are in a brightly lit room or in front of a window. It could also be because it is the middle of the screen and if you carry it in a bag sometimes for put pressure on the back then it can push the LCD from behind and may cause an issue.
Hope this Helps
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 351
