The Logitech K480 is a multi-device keyboard that connects via Bluetooth. It provides an easy way to multitask and connect to most devices.
Logitech K480 won't light up with new batteries?
Batteries were dead, so I replaced them with new ones. No response. The PC|i buttons would not show any light. Connection to the computer did not show up. I was using new batteries. I switched out for a different set of new batteries. Still no response.
3 Comments:
On/off switch seems loose.
by
Are the battery terminals corroded?
by
@dcblack, did you purchase these batteries from iFixit?
by
Add a comment
1 Answer
If the battery terminals are corroded, clean them with some Isopropyl Alcohol, or try to wipe or scrape it off if you don't have Isopropyl. If it's a power switch issue like you said, open it up and test by using a metal object to short the pins on the power switch and see if it turns on. If it does with that, you will need a new power switch.
Add a comment
Add your answer
David C Black will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 10
Past 30 Days: 46
All Time: 145
