Repair guides and support for automobiles by Volkswagen.
172 Questions View all
Coolant system overheats fan on 2005 VolksWagon Jetta?
2005 VW Jetta overheating due to fan inop
Comments:
What model is it and what engine does it have?
by
Have you checked the fuse for the cooling fan to see if it's blown?
by
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
My wife's 2002 Audi had a similar problem. The fuse holder is made of plastic and over time, the heat generated by electricity flowing through the cooling fan fuse caused the terminals that hold the fuse to spread out slightly. Checking the fuse on the top side (with a test light) showed power on both ends, but after removing the fuse, it was apparent that the plastic had melted just slightly.
Instead of replacing the entire fuse box ($90+ part) I opted to add a new separate fuse holder for just that one circuit. Here is a picture of my repair: link The bad fuse location is the empty one next to the 2 green fuses (on the right).
Hope this helps,
BILL
Score 2
Add a comment
Add your answer
rich stevens will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 9
All Time: 499
