MacBook Pro models with 13" displays
5178 Questions View all
start up is very late why?
Start up takes lot of time and this problem started only now,spinning wheel rotates more than 5 minutes fot the start up to commence,after that every time when i click operation the technic colour wheel starts rotating how do i resolve it please guide me
Thanks a lot for the wonderful tip,defrager utility can it purchased separately i am from india please guide me i have about 60 gb free capacity
Add a comment
1 Answer
Chosen Solution
Is your hard drive very full? If so try deleting some things to make more free space (aprox 1gig).
If you have enough free space then your drive may need defragmentation. You'll need to get a utility program to do this. But before you do you want to make sure you have a good backup of your stuff. Get a Firewire external drive that is at least the same size if not bigger than your laptops hard drive. Once you have backed up you can run the defrager utility. A different approach if you don't want to buy the utility is to reformat the hard drive after making the backup and then copying back the backup files back on to your laptop. As long as you don't install a fresh OS on the internal drive this also works.
Lastly, your hard drive may be going bad at which point you'll need a new one. Consider how much stuff you have on your system now that you want to keep and how much space is left on your internal hard disk. If you find your need more space think about getting a bigger drive. But before you go there make sure you have a backup of your files.
Add a comment
Add your answer
NARAYANAN LAKSHMANAN will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 240
