The 7th generation Honda Accord, from 2003-2007.
The clutch makes a squeaking noise
Hello everyone,
My pedal clutch makes a squeaky noise every time is pressed. I tried using a lubricant spray that worked for a little while but the problem came right back. I wonder if this is a common issue.
Score 1
Add a comment
1 Answer
Most Helpful Answer
@sosa90456 not sure how common it is but it does happen. That is why Honda shows the lubrication points in their FSM
Depending on your mileage and if those are mostly City or Highway miles, the pins and bushings can wear as well, which will lead to more squeaks.
Here is the Clutch chapter form the manual. Just in case you have to dig deeper.
Score 1
1 Comment:
I did not know there was a lubrication point for the clutch. Thanks for the information, I will @%^!* the problem and get back to you if resolved.
by
Add a comment
Add your answer
Sosa will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 21
All Time: 80
