Why is my engine oil linking
Hello Bitrus,
I recently discovered the source of my engine leak. It was the valve cover.
To better address your question, you’ll need to clean the area where it’s wet or covered in oil. Drive a short distance and check again. You should find something after cleaning.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 17
All Time: 90
1 Comment
Where is the oil leaking FROM? We're not clairvoyant, we rely on you to tell us these things! You might have to go get your undercarriage washed so you can then trace the leak back to the source
by brandon k
