Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1464 Questions View all
Power button not turning on computer, but will turn it off?
Laptop would not turn on. Light on Magsafe would not light. Replaced magsafe adapter with known good adapter in a known good power outlet. Replaced DC-in board. Light on magsafe only comes on full sometimes. Power button will not turn on computer. If topcase is disconnected, light on magsafe will turn green. Laptop will turn on via the two jumper points next to where the topcase plugs in. Laptop will boot fine and all the keys on the keyboard work. Power button WILL shut off the laptop. Computer will attempt to shut down after a couple minutes. Reset all the energy management settings to not turn off the laptop for any reason. Ran Hardware test (the extensive option. Took an hour or so. Laptop did not shut off) Hardware test checked out fine. Behavior is the same with or without the battery.
I am completely at a loss now. From my view point, everything seems to work on it's own, but not when it is all put together. Could this be a software issue? Is there something that I could be missing? How accurate is the built in Hardware test?
Any help would be great. Thanks.
Add a comment
Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
Browse Our Store
1 Answer
Chosen Solution
This is just n educated guess so nothing for sure. It sounds to me like your upper case may have a short in it which doesn't allow the computer to turn on. This may be because the short is sucking power and cannot allow the system to boot. I would see if any neighbor of friend has a MacBook that you can swap top cases with to see if it is a problem with your top case.
Hope this Helps
Comments:
And Presto!!!!! Replaced topcase with a new one and works like a charm. Thanks for the guess!!!!
by
Add a comment
Add your answer
arcticsgt will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 416
