Early 2011 model, A1278 / 2.3 GHz i5 or 2.7 GHz i7 processor.
616 Questions View all
How to change the display case?
Thanks
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
You can start with the display assembly guide, which will get you most of the way there. Assuming that you're trying to replace the display case and the glass/LCD are fine, you'll have to remove everything from the display case. Start with the mid 2010 LCD guide; the machines are almost identical. From there, it will just be removing small things such as display hinges and antenna cables to get down to the bare display case.
MacBook Pro 13" Unibody Mid 2010 LCD Image
Guide
MacBook Pro 13" Unibody Mid 2010 LCD Replacement
Difficulty: Very difficult2 - 3 hours
Add a comment
Add your answer
Biang will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 1,082
