Redmi Note 8: Charging port failure recurred after repair
Hi everyone,
I’m having a persistent charging issue with my Redmi Note 8 and would appreciate some technical advice.
The Problem: My phone has stopped charging completely. When I plug in the cable, there is no vibration, no charging icon, and the LED indicator doesn't light up.
Background:
- This exact issue happened about 1 day ago.
- At that time, I had the charging port board (sub-board) replaced at a local shop, and it worked fine until now.
- Recently, the charging became "ficky" (intermittent) – I had to wiggle the cable to get it to charge – before it died completely today.
What I’ve tried so far:
- Cleaned the USB-C port with compressed air and a toothpick (no lint found).
- Tried multiple official Xiaomi cables and power bricks (all work fine with other devices).
- Inspected the port for physical damage; the pins look okay to the naked eye.
My Questions:
- Is it common for the charging sub-board on the Redmi Note 8 to fail repeatedly?
- Could this be a loose flex cable connection between the sub-board and the mainboard instead of a broken port?
- Should I try replacing just the charging board again, or could it be a deeper charging IC issue on the motherboard?
Thanks in advance for your help!
Have you tried removing the cable, turn it over then re insert it. If it's the second daughter board it could mean a problem with the motherboard itself. Is it the original cable and charger that came with the phone?
by Ted
