Repair guides and information for rice cookers.
Just warm not cooking Even its in cooking mode
My rice cooker is in cooking mode but its not cooking just warming
Score 1
Add a comment
1 Answer
1️⃣ Heating Plate / Heating Element Issue
Even if the light shows “Cook,” the main heating element may not be getting full power.
If the heater is weak or partially damaged, it will only keep the rice warm instead of boiling water.
Fix:
The heating element needs to be tested with a multimeter. If faulty, it must be replaced.
2️⃣ Faulty Thermostat (Most Common Cause)
Rice cookers have a thermostat sensor at the bottom.
If it is stuck or damaged, the cooker switches to “Warm” mode too early.
Fix:
Check the center thermal sensor (small round button under the pot).
If it doesn’t move freely up and down, clean it.
If damaged, replace the thermostat.
3️⃣ Dirty or Uneven Inner Pot Contact
If the inner pot bottom is dirty, bent, or not sitting properly, heat transfer won’t happen correctly.
Fix:
Clean the bottom of the pot and the heating plate.
Make sure the pot sits flat and centered.
4️⃣ Low Voltage Supply
If voltage is low, the cooker may not reach boiling temperature.
Fix:
Try a different wall socket.
5️⃣ Thermal Fuse Problem
If the thermal fuse is weak, it may prevent full heating.
Fix:
Needs internal inspection and replacement if blown.
Add a comment
Add your answer
Raju Syangtan will be eternally grateful.
Past 24 Hours: 7
Past 7 Days: 30
Past 30 Days: 54
All Time: 54
