My ophthalmoscope is not charging
When I attach my opgthalmoscope to the charging dock it keeps on flashing lights fromcthe globe head but does not charge or turns on when I use it
If the globe head flashes when docked but won’t power on:
Fix:
Replace the rechargeable battery inside the handle.
(These typically use Welch Allyn rechargeable NiMH or Li-ion handle batteries depending on model.)
If the light flashes but no charging happens:
Fix:
Clean with:
Even if it lights up, the dock may not be delivering proper voltage.
Check:
If flashing happens only when slightly moved:
This requires opening the handle carefully.
Some Welch Allyn rechargeable handles need:
Try:
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 32
All Time: 32
