Battery drains after analog stick replacement
I replaced the analog sticks in my Pro Controller but now the controller drains the battery, from full to dead in just a few hours - not being used, the Switch is off, the controller is off. I've confirmed the battery does charge to full and works fine for gaming. I've switched the battery itself with another controller and confirmed that's not the issue. The controller works fine plugged in as well. It's just a matter of the battery draining quickly while not in use.
Did I mess something up when I replaced the analog sticks? Is there anything I could check or do to try to correct this issue?
