I don’t know how to take my laptop screen off
Hi! I was able to take the bezel off of my laptop but I’m confused on how to take the screen off. There are no screws that I can see that I’m supposed to take off other then the 2 hinges on the bottom of the screen which I’m assuming I’m not supposed to take off.
If I could get some advice it would be much appreciated. Thank you!
I put 3 pictures of the laptop if that might help.
Score 1
Add a comment
Chosen Solution
Hi @jackmain
Here's the hardware maintenance manual for the laptop.
Go to p.45 (51 of 64 pdf) in the manual, to view the procedure to disassemble the LCD module
Score 3
1 Comment:
Got it! I was able to take off the adhesive on the back and replace the screen. Thank you so much Jayeff!
by
Add a comment
Hi @jackmain
I would remove the 3 screws of the bottom hinges to have an easier access to the screen itself.
But be careful not to lift the screen out as it is still connected in the back. As seen on this photo
the inner frame and bezel is held on with the clips I circled whick you will need to unclip by gently popping the screen out with a flat tool.
Then you should be able to fold the screen down and disconnect the screen connector in the back.
Score 1
2 Comments:
Thank you, Honakrisi! I was able to remove the screen and replace it!
by
Perfect! I’m glad to hear it!
by
Add a comment
Add your answer
Jack Main will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 12
All Time: 66
