Shop the Holiday Gift Guide
Access comprehensive repair guides, troubleshooting solutions, or any other valuable information here to keep your HP Elitebook 745 G6 running smoothly.
Battery is fat and the screen is not coming πŸ˜”.
I tried to remove battery and then i power it then also the light of keyboard or on but only screen is not working or coming 😞. Pls help me.
My gmail- yashverma95260@gmail.com
Response me πŸ›
Add a comment
1 Answer
Most Helpful Answer
You actually have two separate problems here.
First, the swollen battery β€” that needs to be removed and replaced.
A β€œfat” battery is not safe to use. Don’t try to charge it again.
You can test the laptop with the battery removed and only the charger connected.
Now about the black screen:
Since the keyboard lights turn on, the laptop is getting power. That usually means it’s not a total power failure.
Try to do these things:
Power the laptop on and shine a flashlight directly at the screen from very close range and look carefully from different angles.
If you can see a faint image in the background, the backlight (or the LCD panel itself) has likely failed.
If there is absolutely no image at all, try to connect an external monitor or a TV with HDMI
If the external display shows an image, the problem is most likely the internal screen or the display cable.
If none of those worked, try to carefully open the back cover, and remove the RAM for a minute, then put it back in (you have to hear the click sound when it pops up into its place.
Let us know if any of those advices helped!
Score 3
1 Comment:
merci beaucoup je comprends mieux...!
by Share
Add a comment
Add your answer
Yash Verma will be eternally grateful.
Past 24 Hours: 5
Past 7 Days: 15
Past 30 Days: 51
All Time: 170
