My first screen is broken and laptop isn't power on
I had accident and during accident my laptop is crushed first screen and now I need replacement screen and guide how to replace and how tk.fix it i have important data in it which I need any cost
Add a comment
1 Answer
Hi @harvi
Here's the hardware maintenance manual for the laptop.
Go to p.40 (47 of 64 pdf) to view the procedure to remove the top screen LCD module.
There are two LCD modules that are used in the laptop.
They are Lenovo part # 5D10S40010 and 5D10S40009
I'm not sure what the difference is between them as their specifications seem to be the same but according to the Lenovo parts list they are not interchangeable -see image below no substitutes shown for either panel
It may be best to check the part number of the LCD module in your laptop to verify which one you have before ordering a replacement. The part number is usually found on the back of the LCD panel itself. You have remove the panel first of course to see it.
If you need the data urgently you could always remove the SSD from the motherboard (see p.36 (42 of 64 pdf) of the manual and then purchase an M.2 pcie to usb adapter, plug the SSD into the adapter and then connect it to a USB port in another computer and get the data you want off the SSD that way
(click on image)
Add a comment
Add your answer
Harvi will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 12
All Time: 44
