Released November 2020, the PS5 console features vastly upgraded visuals and an innovative new Dualsense controller. The space-age black-and-white color scheme is a noticeable departure from PlayStation designs of the past.
My ps5 disc drive is making weird noises and doesn't read any disc
Whenever I put a disc in it it makes weird noises over an over until it says can't recognize the disc I tried 5 disc and still won't recognize it when it does the sounds it sounds like it's trying read the disc but cant it even makes the ps5 sound like it's turning on or something
Add a comment
Most Helpful Answer
Hi, @pablo6180 I gotchu.
Looks like you will need a PlayStation Toolkit and a DVD Drive Replacement.
To do that, you can't simply replace the disc drive on your PS5. FixBot said the daughterboard must be transferred from the old drive to the new one.
Before repair, check the following: PlayStation 5 Disc Drive Won't Work - iFixit Troubleshooting
The essential, premium opening tools and screwdriver bits you need for PS1, PS2, PS3, PS4, and PS5 console and controller repairs and cleaning. Image
Product
PlayStation Toolkit
$14.99
Score 2
Add a comment
Hi!
Before replacing the whole drive, I would suggest to replace the laser deck first and see how that goes.
Cheaper and less parts needed to do the repair.
You can follow this guide for that: PlayStation 5 Optical Drive Laser Replacement
You can replace the drive to fix it, but this could help you too. If this fails, then I would return the part and get yourself a new disk drive..
Score 1
2 Comments:
What do I do if my PlayStation 5 doesn't read disks because I cleaned it and took it apart and it still won't work so what do I do
by
Have you connected all the cables? What error do you see? Most of the time it is related to the ribbon cables if this is the case.
by
Add a comment
Add your answer
Pablo will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 59
All Time: 423
