Repair, disassembly, and troubleshooting information for the 2nd generation Moto G Play, a Motorola smartphone released in 2023. Identified by model number XT2271.
put phone in shower a bit it now has horizontal n vert lines a fix?
I put my phone in my shower and some water driped into it and now it has horizontal and vertical lines does anybody know a fix?
Add a comment
Most Helpful Answer
Hi @zennyme
The impurities in the water causes corrosion and provides circuit paths for the electricity which were not in the phone's operating design and could damage the components. The corrosion starts immediately and is ongoing until it is completely cleaned away
First do not try to charge or to turn on your phone and then remove the battery as soon as possible from the phone to minimize any further damage.
Then you need to dis-assemble the rest of the phone and clean all the affected parts using Isopropyl Alcohol 99%+ (available at electronics parts stores) to remove all traces of corrosion and water. If possible do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain additives which may leave conductive residues and is not as effective. If you do have to use it check the label to verify the amount of IPA. The higher the percentage of IPA the better
Here is a link that describes what happens. Electronics Water Damage
As always with electronics, especially surface mounted pcb be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board. Remove the shields that may be covering some components as the water may have got in under there. The ends of any flex cables and their connectors need to be cleaned as well
Hopefully after you have done all this the phone might possibly work correctly again.
Here is the ifixit Motorola Moto G Play (2023) Teardown guide that may help.
If this process seems too daunting, take your phone to a reputable, professional phone repair service, experienced in liquid damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later.
Score 1
Add a comment
Water damaged electronics are the bane of repair. No one enjoys trying to repair them, and it mostly ends in sadness.
You could try taking it apart, and cleaning out the water. You would need to do this rather soon, the more you use the phone the more potential damage will occur. It's likely that things are beyond reasonable repair. Water damage is mostly fatal.
Add a comment
Add your answer
zennyme will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 6
Past 30 Days: 27
All Time: 27
