The G71t-300 is a laptop released by HP in August 2009. It is an all-purpose consumer device complete with an integrated webcam, graphics card, and Windows 7 operating system.
Why is there no picture on the screen but the laptop goes on.
Laptop goes on but screen stays blank
Add a comment
Most Helpful Answer
@marky14530 could be a few issues. Start off by connecting an external monitor. If that displays properly, you know that the issues is related to either your screen or the display cable. Should an external monitor also fail to show an image, then it is possible that your computers issues are related to a bad GPU or other motherboard issues. Use the HP G71 Maintenance And Service Guide to work on your computer. Let us know what you find out.
Score 1
Add a comment
If your laptop powers on but shows no picture, the issue could be display, RAM, or graphics related. First, increase brightness and check if you see a very faint image using a flashlight—this indicates a failed backlight. Next, connect the laptop to an external monitor via HDMI. If the external display works, the laptop screen or display cable is faulty. If nothing appears externally, reseat or test the RAM, as loose memory can cause a blank screen. Also try a hard reset: unplug charger, remove battery (if possible), hold power button 15 seconds, then restart. Persistent issues may require professional repair.
Add a comment
Add your answer
Marky will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 38
All Time: 38
