The Acer TravelMate X349 is a business laptop made by Acer. This page contains repair and service information related to the Acer TravelMate X349.
How do I fix my mouse pad
So I was using the laptop normally until the mouse pad stopped working so how do I fix it?
Add a comment
Hi, @ahmedayman93805 I gotchu.
I found the replacement mousepad here. Ask FixBot to assist you with replacement.
Add a comment
Well Check the "Magic" Function Key and also check for driver sometime outdated driver can also be the reason of this issue.
Add a comment
If your laptop touchpad suddenly stopped working, start with simple checks. Make sure it isn’t accidentally disabled—many laptops have a function key (Fn + F-key) to toggle the touchpad. Restart your system, as it may be a temporary glitch. Go to Device Manager and check if the touchpad driver is missing or needs updating; reinstall it if necessary. Also check Settings > Touchpad to ensure it’s enabled. Disconnect any external mouse, as some systems disable the touchpad automatically. If none of this works, it could be a loose internal cable or hardware failure, requiring professional repair.
Add a comment
Add your answer
ahmed ayman will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 15
All Time: 47
