Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1409 Questions View all
Is it the invertor board or do I need a new panel?
It takes three or four tries of opening and closing the macbook to get the login screen to light up. When it is "dark" I can see everything perfectly with a flashlight, computer is fine. After several tries of open/close, the login screen will be light and I can login and use the computers for hours with no issues.
I took it to apple store and they replaced the cable ($6.89 + $39 labor)
I took it back cause the problem is still there. Now they want to replace the entire display for $250! My research is showing it could be invertor board which is only $39.
anyone have any experience in this? How can i know if the entire display panel needs replacing or invertor board. I am curious why I need a new display when it only happens at login and no other times.
any help is appreciated
Add a comment
Chosen Solution
It could be the inverter board you could replace it DIY - they are not expensive or hard to get at. You could have a bad connection to the LCD (especially if the laptop was dropped).
If this Answer is helpful please remember to return and mark it Accepted.
Score 1
Add a comment
Most Helpful Answer
Here's how to replace the inverter: MacBook Core 2 Duo Inverter Replacement Here's the part: MacBook Display Inverter Here's how I do it if you don't need to replace the cables: MacBook Core 2 Duo LCD & Inverter A1181 (fast method) Replacement
MacBook Core 2 Duo Inverter Image
Guide
Difficulty:
Difficult
2 hours
MacBook Core 2 Duo Installing LCD & Inverter (fast method) A1181 Image
Guide
Difficulty:
Moderate
1 hour
Score 2
Add a comment
Add your answer
Pilar will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 660
