if I touch it with edge of my finger it doesn't work.
I already try to do it on my other phone and it's work, so it's not my finger that cause it
@reno23787 since it does work, just not while you use the edge of your finer, this will be an issue with the sensitivity of the digitizer. I would check the settings within the phones software. See if you have settings for something like "Touch Sensitivity" or "Screen Protector Mode" in the Display menu that you can change. Of course, you could try and change the display assembly of which the digitizer is a part off, or just continue to use your whole finger instead of just the edge.
is my screen protector/tempered glass can be the issue ?
@reno23787 yes absolutely. Check your settings since some of them do have settings for the screen protector mode
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 39
All Time: 39
2 Comments
@reno23787 does it work when you use the whole pad of your finger instead of just the edge?
by oldturkey03
@oldturkey03 yeah it work
by RENO
