The Levoit LVAC-200, a cordless vacuum cleaner introduced in November 2023 and identified by the model number LSV-V201-WUS, offers efficient cleaning solutions for various surfaces.
New cleaner not charging, red light blinks and no change
Once plugged in, red light blinks, low volume sound rings. It doesn't charge at all and its a brand new vacuum cleaner. It doesn't turn on either.
Add a comment
1 Answer
Most Helpful Answer
Hi @nachojozami
Have you tried removing the battery from the vacuum cleaner and then connecting the charger directly to the battery, to see if it started to charge?
See p.10 of the user manual
Since it is new, try leaving the battery on charge for at least 3-4 hours to see if the battery is kick started back to life and begins to charge.
If still no good, return the vacuum cleaner for a warranty replacement or refund.
Score 1
Add a comment
Add your answer
Nacho Jozami will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 28
All Time: 38
