CDMA version of the fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. 16 or 32 GB / Model A1349 / CDMA compatibility.
419 Questions View all
Are pentalobe screws still good after removed?
i was replacing the back of my iPhone to make it red, i put the new back in and tried to put back my pentalobe screws but they wouldn't go back, is this supposed to happen, do i need to buy Phillips screws instead??
Add a comment
MacBook Battery Fix Kits
Fix Kits Starting at $69.99
Starting at $69.99
Chosen Solution
Yes, just like any other screw, as long as the correct bit is used to remove it, it will go back in just fine. Did you use a proper pentalobe screwdriver, or something else as a stand-in? Our iPhone liberation kit uses a standard star bit to remove the pentalobe screws, which strips them, which is why we then include Phillips screws to replace them.
Score 1
Comments:
I ordered a new backing, it was sent with two screwdriversmid didnt know which was which and i think i used the wrong one
by
Add a comment
Most Helpful Answer
Check if the new back cover is seated properly. Screw should go back in provided that its head is not damaged when you removed it. Use the correct screw driver to remove screws.
Score 1
Add a comment
Add your answer
Ryan Martins will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 2,888
