Released November 2020, the PS5 console features vastly upgraded visuals and an innovative new Dualsense controller. The space-age black-and-white color scheme is a noticeable departure from PlayStation designs of the past.
Console Randomly Turned Off and Now Won't Turn On
Console turned off randomly while playing a game. Now the console won't fully boot.
Pressing the power button the first time causes the console to beep and nothing else. Pressing the power button a second time has it appear to attempt to boot up. You can hear the fan and disc drive. You'll see a blue light for around 5 seconds, then it'll become a white light for around 20 seconds, and then the console powers itself off.
During all that, the monitor does not have a signal.
Holding the power button for Safe mode sometimes does work. When it does go to safe mode, pressing many of the options shows the screen freeze and turn off after a few moments. When holding the power button doesn't go into safe mode, you'll hear a first beep after holding the button for 7 seconds, then a second beep after 7 more seconds, then after another 7 seconds the console automatically turns off.
I've tried unplugging the console for a few minutes.
I tried a different wall outlet, different power cable, and replaced the PSU with a new one.
Add a comment
Most Helpful Answer
Hi!
I'm afraid the southbridge is having issues here.
I would replace that one and see how it goes.
Part: https://www.aliexpress.us/item/325680586...
Be aware: It's NOT easy to replace this one. Soldering is required together with soldering skills. Otherwise I would ask a local repair shop to do it for you...
Can you let us know how that goes? Thanks!
Score 1
Add a comment
It sounds like either a failing part or system data corruption, but I'm not a professional by any means whatsoever.
Add a comment
Add your answer
Bob Bob will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 33
