Model A1019 / 10 or 20 GB hard drive / full-size Firewire port
29 Questions View all
Can't restore old iPod 2G Touchwheel
Hello. I bought this pretty rare iPod on eBay. It was in very good cosmetic conditions and worked perfectly except that I could'n sync it with my Macbook Pro 2008 because iTunes didn't recognize it. But it was recognized by Disk Utility as an external hard drive. So I decided to format it and restore in iTunes. There was no problem with formatting it. However iTunes refused to recognize it again. I tried my old Mac Mini G4 with Tiger and iTunes 4 recognized it but there is no opiton to restore it.
Any advice is welcome
Score -1
Add a comment
1 Answer
Chosen Solution
Dmitry Rodin, first thing I would try to do is to place it in diagnostics mode. Follow the instructions from here. See what the diagnostics reveal. Also, check to see if you can access your hard drive in disk mode, just to make sure it is okay. Verify that your firewire port does not show any corrosion etc, and use a known good firewire cable. Of course you do know that in order to finish a restore, you must have a firewire ac adapter. So it is possible that you iPod is stuck in a restore mode and needs to be plugged in to an AC firewire charger. Give it a try an let us know
Score 1
Add a comment
Add your answer
Dmitry Rodin will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 957
