The Bambu Lab A1 Mini is a desktop 3D printer released in the fall of 2023. The A1 Mini features full-auto calibration, 4-color printing with the AMS lite, and functions under 48 dB in Silent Mode.
Bambu Lab A1 Mini extruder clicking and filament feed issue
Hello,
I’m trying to troubleshoot a hardware issue on my Bambu Lab A1 Mini Combo 3D printer and would appreciate any guidance.
Hardware reference (for clarity): Bambu Lab A1 Mini Combo 3D printer
Issue description:
During prints, especially at higher speeds or when more filament is needed, the extruder begins to click repeatedly and the filament feed becomes inconsistent. This often results in under-extrusion or gaps in the print. The printer pauses or slows unexpectedly as well.
What I have checked so far:
  • Filament spool tension and re-feeding
  • Nozzle temperature settings
  • Cleaned the nozzle and heat break
  • Verified filament is not tangled
At this point I’m trying to determine whether this is likely due to a mechanical feed problem (gears, tensioner, idler), a drive motor issue, or a sensor/stepper calibration issue.
Specifically, I’m interested in:
  • Common mechanical causes of clicking extrusion on this or similar models
  • How to inspect the extruder gears and tension assembly safely
  • Any recommended checks for stepper motor performance or idler alignment
Thanks in advance for any repair/inspection advice — I’m trying to identify whether this is a hardware fault or a setup calibration issue.
Score 2
Add a comment
Most Helpful Answer
I've had this problem with my a1 were it clicked and ruined my prints. I found frome someone else that there were loose screws that I needed to tighten and it fixed it.
If you take the head out there will be 3 screws behind holding the heat break on, if you unscrew those and carefully pull it away from were its mounted on the back of it are 4 tiny screws that were loose for me. If you tighten them and re assemble everything following with a calibration bed level it should hopefully fix issue .
Here's i link to a video to help explain were the screws are
https://youtu.be/J846AzEy6WU?si=uxlTMMJ6...
Score 1
Add a comment
In my experience when the extruder is clicking while running - especially at high speeds, it is because the filament is unable to be fed through fast enough. Verify the filament you are using is compatible with the speeds you are printing, as not all filaments support high speed printing. Consider trying slower print speeds, as it may not be a printer issue causing your issue.
Add a comment
Add your answer
Daniel DSouza will be eternally grateful.
Past 24 Hours: 4
Past 7 Days: 26
Past 30 Days: 78
All Time: 269
