A laptop series by HP. Identifiable by the model number G62-XXX-XX, endings vary depending on options and seller.
19 Questions View all
How do I install a screen on my HP g62143cl Notebook?
HP g62143cl Netbook needs the screen to be replaced because it is cracked. The screen is not visibly cracked. When it is turned on, the crack becomes visible (internally cracked). Called HP and they said it needs a screen replacement. If I purchase my own screen how do I install it?
Add a comment
Chosen Solution
You can probably get the screen here: http://www.laptopscreen.com/English/mode...
Here's a video on replacing it: http://www.youtube.com/watch?v=IePdjRTMQ...
Score 4
Comments:
and here is the maintenance and service guide http://h10032.www1.hp.com/ctg/Manual/c02...
by
My screen is not physically cracked on the outside. There is no visible crack. However, when I turn it on, the image itself is cracked. Would I still go about replacing the whole screen or is it something else?
by
Yes Teryn H, you are definitely describing a cracked screen. You will have to replace the whole LCD....
by
Thank you very much! My screen is now fixed (:
by
Add a comment
I am using HP G62 after 3 years of use my screen become completely white without any prior issue.
Kindly help me, should I buy a new Screen or any issue to check it.
Add a comment
Add your answer
Teryn H will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,101
