Hi @irfanardiansyah
Try a power refresh and check if that resolves the problem.
Here’s the procedure:
Disconnect the charger from the laptop, (if connected).
Open the laptop and disconnect the main battery from the motherboard. You don't have to remove the battery, just unplug the battery cable from the motherboard
Disconnect and remove the RTC coin cell battery from the motherboard.
Here’s the hardware maintenance manual for the laptop that will help. It shows how to disconnect the main battery (see p.29 of the manual - 35 of 66 pdf) and also how to disconnect the RTC coin cell battery (see p.36 of the manual - 42 of 66 pdf)
When the RTC battery is out check its voltage. if it is <2.5V DC or if the battery is >4-5 years old, replace it. Search online for 5B11F14640 or 5B11F14639 to find suppliers that suit you best
Press and hold the laptop’s Power On button for a full 30 seconds and then release it.
Reconnect the RTC coin cell battery on the motherboard, reconnect the main battery to the motherboard, re-assemble the laptop, connect the charger to the laptop and try to start it.
If it starts, there may be a message about the date and time being incorrect. This is normal as the above procedure has reset the BIOS back to its factory defaults. Once the date and time have been adjusted, the message won't appear the next time the laptop is started. Any user defined BIOS settings that have been altered by you to suit your particular requirements will need to be changed back also.
