PS4 will not turn on.
My PS4 will not turn on. The light bar lights up for a split second then nothing, no beeps. I've replaced the power supply because I thought that was the issue. However it did not fix it, Seems pretty clean inside so I doubt its corrosion. Any ideas? I'm thinking maybe a resistor or cable connecting to the board.
It did turn on when I first got it. But after about 5 minutes it died.
by ANTI
@anti11118
But it doesn't turn on now or does it turn on and then off after 5 minutes?
You originally said that it doesn't turn on, so my answer was predicated for that problem.
If it doesn't turn on as you first said, try the answer below.
by jayeff
@jayeff Doesnt turn on now. Only that first time I used it.
by ANTI
@anti11118
You said "... when I first got it"., which makes it seem like it's a used console. If it is, do you know its history, was it described as fully working etc?
Try the answer below.
If the battery is the problem at least if it starts regularly (after replacing it) and then it turns off later you are a step forward into finding out what else is wrong.
At the moment you can't even get it to turn on and stay on.
by jayeff
