iPod won't turn on after display assembly replacement
So I was fixing an iPod touch 4th generation display assembly and When I put it all back together, the screen was all white. It was recognized by itunes, however. Thinking it was just a mispositioned LCD cable, I unplugged the iPod from my computer (the battery was pretty low) and opened it up to re-position the LCD cable. So I did so and I believe the battery died. Now It does not seem like the device is getting any power. I tried different USB ports, cables, etc.
When the screen was white it did not seem like the power button was working; after it went to sleep i could only awake the screen using the home button.
Right now It's plugged in but does not seem to be getting power and is not being recognized by itunes.
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
It sounds like you may have torn the power button flex cable. Very easy to do on the repairs on these.
Add a comment
U may have to press it down more, mine did the same thing, keep re0assembling till it works...can take a few hours worth of tries. Plug it into the computer or listen for like a electrical "hum" near the tiny IC island thats located to the right volume control uttons where the logic board is laying. If theres a hum, there is power and just most likely may need an adjustment.
Add a comment
Add your answer
bdow will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 2,372
