The First Alert OneLink Safe and Sound Smoke Detector is a customizable smoke alarm with a built in Alexa to provide hands free communication and a premium built in speaker. It was released in 2018, identified by model number 1039102.
Getting false alarms—can the detector sensors be replaced?
Thanks for all of your info, how/can I replace the detector? I have false alarms now, I done the test and cleaned, and as you know, first alert is no help.
Maybe I can reset the entire device and start over, any suggestions
1 Comment
@troyfralick here us how to reset it but it sounds more like an issue with the CO sensor.
by
Add a comment
1 Answer
Chosen Solution
There is very little you can do to overcome an alarm which is firing off sporadically. This could be dust collected within the detectors sensor area or the sensor its self has failed.
Here's a simple image on how your smoke detector works
Ionization smoke detectors use a small amount of radioactive material, americium-241, to detect smoke. So while the Americium-241 half life is quite long, the sensor plates can degrade over time. Sadly it's time for new detector if dusting it out doesn't help. Do make sure you dispose detector properly as it shouldn't get into our water or ground.
Score 1
Add a comment
Add your answer
Troy Fralick will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 27
All Time: 162
