2.26 or 2.4 GHz / White plastic unibody enclosure
624 Questions View all
Advice for stripped screw on rear vent?
I ended up stripping out the screw on the right side of the rear vent on step 4 Installing MacBook Unibody Model A1342 Dual Hard Drive
Due to lack of wanting to put a lot a pressure because i was scared id crack the screen :/
Any advice on how to extract this one at home given the location of the screw?
The dremel trick actually worked and allowed me to keep the old screw until i can get a replacement :D
Add a comment
Chosen Solution
Precision Screw Extractor Set
I just ordered these and am interested to see how well they work: Screw Extracting Pliers
What are your tips/tricks for removing or extracting stripped screws?
Score 3
Add a comment
I actually stripped the same screw on one of those, I ended up grinding the metal lid off the rear vent where the screw was attached to. The screw goes straight into the casing and not through the mainboard, so it didn't do much harm.
Next time I'll be going for a more subtle approach with one of those pliers, though..
Add a comment
Add your answer
truehybridx will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 966
