Support and repair guides for the 2002-2008 Mazda 6. The first generation of the Mazda 6, also known as the Mazda6 and the Mazda Atenza (in China and Japan).
mazda 6 not starting at all
my mazda6 2028 cannot start at all.. already diagnose its say the steering lock column locked.. how to repair??
1 Comment
Just to clarify, your Mazda 6 is a 2008, rather than 2028 (which would be a very good trick), right?
by
Add a comment
1 Answer
Most Helpful Answer
Assuming I've read your question correctly, my interpretation is that you feel you need to replace the steering lock mechanism on the steering column, is that correct? If that's the case, the following section of the repair manual will show you how to do that replacement.
Steering Column: Service and Repair — 2008 Mazda 6 L4-2.3L Service Manual - Operation CHARM
My problem is that the column lock doesn't have anything to do with whether you can start the car or not; that should be a function of the ignition switch itself, rather than the steering lock mechanism. The following page shows how to remove the ignition switch without having to dismount the steering lock.
Ignition Switch: Service and Repair — 2008 Mazda 6 L4-2.3L Service Manual - Operation CHARM
Although I randomly selected the L4 engine vs the 6 cylinder since I don't know which one you have, the procedure should be the same; you can always navigate to the appropriate page on the 6 cylinder guide if you want. The preceding pages also have troubleshooting and testing information to help confirm whether the parts are working correctly or not.
Score 1
Add a comment
Add your answer
Apis Ajis will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 14
All Time: 73
