Bluetooth connecting and then disconnecting
I just built my gaming pc and everything is working fine except bluetooth headphone windows 11
2 Comments
Hi @rani39814
What is the model number of the Asus motherboard?
by
Hello @jayeff it is a b850- gaming wifi R2
by
Add a comment
1 Answer
Most Helpful Answer
Hi @rani39814
Intermittent BT (and WiFi) connection problems usually indicate a problem with the antenna/antenna connection in a device.
Have you connected the WiFi antenna to the WiFi ports at the back of the motherboard?
See p.45 of the manual
Bluetooth uses the same antenna as the WiFi as they both work on the 2.4GHz band.
Score 1
Add a comment
Add your answer
Rani will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 22
All Time: 122
