No Audio, or audio without vision - hardware problem?
So I have my Valve Index for a while although use it very rarely and it never had any issues and was never abused dropped etc.
Valve Support don't want to help me anymore and send very vague and random tips and tricks I already saw everywhere on the Internet.
From some time ago it started to behave strange - when I open SteamVR randomly I get a session in which I hear sound but, there is no vision - just grey color. Then after Restart Headset function the vision comes back but there is no sound.
You can believe me I did everything I can to my PC, drivers, bios setups, different ports, registry keys, windows settings - all of it.
I ordered original tether cable from Valve - did not change anything, therefore I assume it must be Headset itself.
Any idea why there can be randomly a session with audio but no vision, or more often a session with vision but no sound at all?
I'm desperate enough to open up this whole thing and start investigating everything on the PCBs but if anyone has any clue where to start that would be great! Thanks!
EDIT:
Does it make sense for me to upload some SteamVR system log dumps?
If so:
1. Here is a log file where after restart I had sound without vision: https://files.catbox.moe/a6yoer.txt
2. And here when I restarted above session and got vision back, without audio, and played a bit with some game: https://files.catbox.moe/kgkhhp.txt
Hey everyone, I'm close to giving up.
New cable, new motherboard, fresh clean reinstall of entire PC - issue is the same.
Logs can be found here:
https://files.catbox.moe/dkgijv.txt
Still seems to cry about:
- [npca110p] ERROR reading chip id after init: [0 0 0] (result: 0)
* [npca110p] Unable to load DSP image (result: 8)
* Followed by: [audio] Nuvoton failed to initialize. May be due to I2S stream fault.
Even after motherboard replacement?
Please let me know if anyone can check this entire topic, dig through these logs and maybe point out what else could be checked and fixed?
Many thanks!
by Bart B
