I'm getting vibration when I apply brakes at high speed
I had this issue with my 17 rdx. It's common (since these are luxury SUVs and heavier) for the rotors to warp if not replaced on time. Depending on how you drive and how often I would recommend replacing your rotors every other time you replace your pads. I had to replace my pads and rotors all around.
Id have your brakes checked and then your alignment.
I just had new front and back brakes put on. I'm wondering if it a caliber?
@ryanjohnst63184 "had new front and back brakes put on" did you have that vibration before? Complete brakes or just brake pads? Have they checked your rotors to make sure they are not warped?
It could be a loose caliper bolt causing the vibration.
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 25
All Time: 152
